Pre 84 Trucks 1st gen pickups
1983 Blinker Relay LED transition- Wiring Help!
Old Sep 23, 2020 | 01:19 AM
randyg3000's Avatar
Unhappy 1983 Blinker Relay LED transition- Wiring Help!
Aloha from Maui, recently upgraded to rear LED lights, which work well but turn signals flash SLOWLY. In attempting to upgrade the old relay I've run into confusion on the wiring. Or, I have the wrong replacement electronic flasher device.
The 3 connectors on the old flasher are labeled L P X and the new electronic flasher is labeled L B E. I'm having trouble with the translation other than L is "Load". Not even sure I have the right device or if anyone else has tried this approach.
I hooked it up with the L and guessed at the other 2, but managed to blow the rear flasher fuse. Perhaps I've fried the new flasher as well, or maybe I have the wrong part entirely.
Thanks in advance for any ideas or guidance!
old and new flasher
Old Sep 23, 2020 | 06:42 AM
Lons81's Avatar
B= battery power, L= load , E= ground. The pinouts are for a led flasher
theragingrussian
Sep 28, 2018 07:00 PM
Mason King
Dec 16, 2015 12:29 AM
☆OMI☆
Oct 31, 2015 10:54 PM
cgeorge
Nov 19, 2009 03:17 AM
dip1
Oct 12, 2008 08:58 AM
