1982 22r BREATHER on valve cover necessary?
I have an operating and functional PCV valve routed directly into the intake manifold. The breather port towards the front of the valve cover is blocked off with a little rubber cap. Should I have a breather on there? I"m not looking to get rid of the PCV, I'm just talking about the other hold in the valve cover.
I'm reading conflicting information on if it should stay capped or whether I should put a breather on there.
What are the pros/cons? It's been on there since I've had the it so I don't know what a breather will help/hurt, etc.
Thank you.
Thank you.
ENIGMA, mine is capped off now and has been for a while. I"m wondering if running it capped off could have caused some problems. I had 2 oil leaks. My oil pan gasket was out of position in one spot (possibly caused by this problem) which I just fixed 2 weeks ago. The other leak I haven't been able to isolate yet. Maybe the increased crankcase pressure caused them. It would be great if adding the breather corrects the existing leak. I'm not holding my breath.
MudHippy
Feb 15, 2018 10:07 AM
FS[PacSouthWest]: 4.56 Front IFS diff + 8" ring and pinion
04sport4x4
Apr 26, 2016 04:35 PM
FS[SouthEast]: 1986 Pickup Bumpers - Front, Valance, & Rear
leviathan278
Feb 26, 2016 12:02 PM
