Pre 84 Trucks 1st gen pickups
1982 22r BREATHER on valve cover necessary?
Old Feb 3, 2016 | 04:37 PM
Joey22r's Avatar
I have an operating and functional PCV valve routed directly into the intake manifold. The breather port towards the front of the valve cover is blocked off with a little rubber cap. Should I have a breather on there? I"m not looking to get rid of the PCV, I'm just talking about the other hold in the valve cover.
I'm reading conflicting information on if it should stay capped or whether I should put a breather on there.
What are the pros/cons? It's been on there since I've had the it so I don't know what a breather will help/hurt, etc.
Thank you.
Old Feb 4, 2016 | 07:26 AM
kawazx636's Avatar
You should have a breather filter on it.
Old Feb 4, 2016 | 11:05 AM
enigmaT120's Avatar
Mine goes into my carburetor air filter.
Old Feb 4, 2016 | 01:17 PM
Joey22r's Avatar
ENIGMA, yes, that is the other option. As it stands, I have neither so I'll just order the K&N breather and use it. I hope I didn't damage anything running without it.
Thank you both.
Old Feb 8, 2016 | 12:08 PM
enigmaT120's Avatar
I think the only risk would be making an oily mess on your valve cover or getting some dirt into your oil.
Old Feb 8, 2016 | 05:08 PM
Joey22r's Avatar
ENIGMA, mine is capped off now and has been for a while. I"m wondering if running it capped off could have caused some problems. I had 2 oil leaks. My oil pan gasket was out of position in one spot (possibly caused by this problem) which I just fixed 2 weeks ago. The other leak I haven't been able to isolate yet. Maybe the increased crankcase pressure caused them. It would be great if adding the breather corrects the existing leak. I'm not holding my breath.
MudHippy
Feb 15, 2018 10:07 AM
04sport4x4
Apr 26, 2016 04:35 PM
leviathan278
Feb 26, 2016 12:02 PM
Grego92
Feb 6, 2016 12:10 PM
Tfalley
Feb 2, 2016 11:06 AM
