Pre 84 Trucks 1st gen pickups
1980 longbed lift opinions
Old Sep 26, 2012 | 08:33 AM
runs-on-4's Avatar
this is one of those trucks you seee and wish it was yours. looks awesome
Old Sep 26, 2012 | 08:51 AM
jslone's Avatar
^^^^^^x2
Old Sep 26, 2012 | 11:31 AM
85toy's Avatar
your shocks are on upside down, they should work a lot better if you flip them around.
Old Sep 26, 2012 | 02:31 PM
cman1's Avatar
the fronts only go on one way, i thought it was weird also.
Old Sep 26, 2012 | 03:10 PM
  #25
83Toyota88's Avatar
Are they really? Mine are the same way. Hmmm.
Old Sep 26, 2012 | 06:48 PM
  #26
caboussleman's Avatar
Looks real good man. it looks like your rear shackle angle is way off.
Old Sep 26, 2012 | 07:23 PM
  #27
NickMiller's Avatar
What size tires are you running?
Old Sep 26, 2012 | 10:01 PM
  #28
cman1's Avatar
33x12.50x15 ,will probably go to a 31/10.50,more user friendly.
Old Sep 26, 2012 | 10:48 PM
  #29
bob200587's Avatar
I think I just had a stroke....
Old Oct 1, 2012 | 01:57 PM
  #30
cman1's Avatar
upon further review,fronts were correct rears were upside down!
Old Oct 1, 2012 | 07:00 PM
  #31
83Toyota88's Avatar
What makes them upside down or I guess how is there a correct and wrong way for the shock to be? Obviously it's something technical, I'm just curious to what it is.
Old Oct 1, 2012 | 07:50 PM
  #32
BMcEL's Avatar
Only monotubes should be inverted. Otherwise, keep them right side up if you can.
Old Oct 1, 2012 | 07:52 PM
  #33
83Toyota88's Avatar
Ok but which way is normal? With the stem and boot on bottom or top? I have ruff country shocks.
Old Oct 1, 2012 | 07:59 PM
  #34
Al's Chop Shop's Avatar
uh, you crammed coil springs between your frame and leaf pack? i'm hoping these are bolted down or something?? i'd hate to be standing or even driving near by when that spring slips out form under the frame. the amount of energy in even a mildly compressed coil spring is pretty intense and could injure or kill someone, let a lone do lots of property damage!
Al
Old Oct 1, 2012 | 08:04 PM
  #35
NickMiller's Avatar
Al
Ever heard of a ZUK mod? Pretty popular actually... It's puts a coil spring between the bumpstops for a bit more lift & flex. I thought people who did it were crazy at first, but I have yet to hear of one slipping out! Google it or search the forums!
Old Oct 1, 2012 | 08:09 PM
  #36
i have seen it before, mostly on old trailers. i would never trust a spring to just stay in place given the amount of forces it sees. yikes.
Al
Old Oct 1, 2012 | 08:34 PM
  #37
BMcEL's Avatar
Inverted is shock body on top.
It doesn't seem safe, but hundreds of people have done the 'Zuk" mod and I've never once heard of a spring dislodging. When done correctly, the spring is still under tension at full droop.
Old Oct 1, 2012 | 08:37 PM
  #38
cman1's Avatar
yep!!!this time its temporary..i didnt have enough cash to get the rear springs yet and had the coils already from a previous zuk mod i did,but NEEDED to put the shocks on.
Old Nov 22, 2012 | 05:13 PM
  #39
MackMan83's Avatar
I know this thread is kinda old but i have an 83 and just got done putting 4 inch lift under the front it but i need longer shocks now and was wandering what yall would recomend that wont break the bank. Thanks
Old Nov 23, 2012 | 07:03 AM
  #40
wolfman81yota's Avatar
If nobody else will say it, I will! THAT IS THE CLEANEST 1st GEN I HAVE EVER SEEN! Do you mind if I ask how much you got her for?
