Pre 84 Trucks 1st gen pickups
1980 20r idles fine,engine dies when accelerated
Old May 2, 2021 | 06:29 AM
David Kuhn's Avatar
Hi. What a great forum.
My truck idles fine but if i try to accelerate it dies. If i floor the gas peddle it gets gas and runs that's how i got it home . Sometimes when i start it, it runs perfect. I changed a the fuel filter. and i changed the throttle plunger when i bought it and put a new float in it. It did sit for a while and the person i bought it from said he dropped the tank and cleaned it out. Thanks for any advice given on how to proceed
Old May 3, 2021 | 05:01 AM
Punjab's Avatar
Aisin carb or Weber? Electric fuel pump or mechanical pump? Spark plugs look chalky or covered in black carbon?
Old May 3, 2021 | 05:31 AM
David Kuhn's Avatar
Aisin carb, new mechanical pump and new spark plugs but I'll check em again..
Old May 4, 2021 | 05:23 AM
Punjab's Avatar
It could be any number of things but on the surface, based on your description, it sounds like lack of fuel. Open the throttle, leans out, dies.
Made sure that you didn't cross the return-to-tank and the fuel-to-carb lines at the pump?
Do you have a timing light to check ignition advance?
Brpherigo
Jul 15, 2020 06:21 PM
Colton 0716
Feb 22, 2016 01:45 PM
20Rheadbanger
Sep 2, 2014 08:36 AM
tolsty
Feb 23, 2014 12:26 PM
