1980 20r idles fine,engine dies when accelerated
Hi. What a great forum.
My truck idles fine but if i try to accelerate it dies. If i floor the gas peddle it gets gas and runs that's how i got it home . Sometimes when i start it, it runs perfect. I changed a the fuel filter. and i changed the throttle plunger when i bought it and put a new float in it. It did sit for a while and the person i bought it from said he dropped the tank and cleaned it out. Thanks for any advice given on how to proceed
It could be any number of things but on the surface, based on your description, it sounds like lack of fuel. Open the throttle, leans out, dies.
Made sure that you didn't cross the return-to-tank and the fuel-to-carb lines at the pump?
Do you have a timing light to check ignition advance?
