Pre 84 Trucks 1st gen pickups
1979 R20 Overheats/L43 Trans goes South
Old 05-05-2019, 02:53 PM
faber's Avatar
Well
Originally Posted by ToyOkie78
I have their regular steel floor jack but an actual trans jack would be nice. The trans alone isn't heavy at all, with the T-case attached that might be a different story
trans out - heavy booger, ordered aisin kit, replaced release bearing, will do pilot - cleaning trans now - will resurface per above and get balanced.
The following users liked this post:
old87yota (05-05-2019)
Old 05-05-2019, 02:58 PM
faber's Avatar
And...
Plan to paint driveshafts low gloss black.
Old 05-05-2019, 03:02 PM
faber's Avatar
One Q:
Re: rear main seal comment above; where is that? Lots of gunk/leakage(?) where front drive shaft meets trans.
Old 05-05-2019, 03:20 PM
Fossilized
Staff
dropzone's Avatar
rear main seal is usually referring to the rear main seal of the crankshaft (you would find it behind your clutch.
the gunk you see where the drive shaft looks like someone getting a little enthusiastic when lubing the u-joints and slip joint and it building up over the years
Old 05-05-2019, 04:35 PM
  #25
faber's Avatar
Re:
Hey, thanks so much - makes sense regarding lube.
Old 05-11-2019, 06:32 AM
  #26
faber's Avatar
Etc
Coming along...
old87yota (05-11-2019)
Old 06-25-2019, 01:44 PM
  #27
faber's Avatar
transfer case shifter bushing?
Update & Question for the brain trust: Trans back in & following through with connections - Question ion: Is there a transfer case shifter bushing for this getup? I saw no evidence of any but I saw a few references in models - I'm still looking into;
This url says it needs one: https://core-shifters.com/products/t...nt=14623531206
I don't think it needs one -
Old 06-25-2019, 02:26 PM
  #28
Lons81's Avatar
Does this help? https://core-shifters.com/products/t...nt=14623531206
Old 06-26-2019, 04:47 AM
  #29
faber's Avatar
Re: bushing
Originally Posted by Lons81
Hi and thanks - I also have that url at the bottom of my post but that bushing underside appears to fit on a flat surface while my 2d pic shows the concave “seat” the shifter “ball” fits in. I’m thinking a little grease without inserting a bushing(?)
Old 06-28-2019, 09:19 AM
  #30
faber's Avatar
Update - ugh
All is in place but clutch is real spongy even after bleeding several times - no apparent leaks from previously replaced master & slave. Slave pushrod is adjusted w/ 1/8" freeplay and is pushing the clutch fork - started engine with truck still on the jackstands and clutch shifts fine but won't engage (not able to shift into reverse - grinding) ...crap....someone w/ lots more expertise is going to drop by and look things over.
Old 06-28-2019, 09:47 AM
  #31
faber's Avatar
Hmmm
Looked at my pedal and some other clutch pedal pics and noticed my return spring was not in place - and the nut on rod to Master Cyl out of sight in pic was real loose and caused play - will adjust and see if I can keep my Man card...
Old 06-28-2019, 12:47 PM
  #32
faber's Avatar
Gimme back my Man card...
Adjusted the clutch pedal per issues above AND took the truck out of H2 (must have knocked it into gear) and took her for a drive - appears to be running like it should. Now on to some body stuff - replace newly painted shields shields underneath & note I took front valence(?) off and replacement is ready for paint then shocks & front springs etc etc...feels good & thanks for helpful expertise from all above -
old87yota (06-28-2019)
Djesch3
01-10-2019 05:48 AM
faber
12-10-2018 12:53 PM
toyotacharles
06-19-2011 07:53 PM
paulacu
08-22-2009 09:09 PM
nate2002
03-12-2004 07:19 PM
Quick Reply: 1979 R20 Overheats/L43 Trans goes South
