1979 R20 Overheats/L43 Trans goes South
Well
The following users liked this post:
old87yota (05-05-2019)
And...
Plan to paint driveshafts low gloss black.
One Q:
Re: rear main seal comment above; where is that? Lots of gunk/leakage(?) where front drive shaft meets trans.
the gunk you see where the drive shaft looks like someone getting a little enthusiastic when lubing the u-joints and slip joint and it building up over the years
#25
Re:
Hey, thanks so much - makes sense regarding lube.
#27
transfer case shifter bushing?
Update & Question for the brain trust: Trans back in & following through with connections - Question ion: Is there a transfer case shifter bushing for this getup? I saw no evidence of any but I saw a few references in models - I'm still looking into;
This url says it needs one: https://core-shifters.com/products/t...nt=14623531206
I don't think it needs one -
#29
Re: bushing
Does this help? https://core-shifters.com/products/t...nt=14623531206
#30
Update - ugh
All is in place but clutch is real spongy even after bleeding several times - no apparent leaks from previously replaced master & slave. Slave pushrod is adjusted w/ 1/8" freeplay and is pushing the clutch fork - started engine with truck still on the jackstands and clutch shifts fine but won't engage (not able to shift into reverse - grinding) ...crap....someone w/ lots more expertise is going to drop by and look things over.
#31
Hmmm
Looked at my pedal and some other clutch pedal pics and noticed my return spring was not in place - and the nut on rod to Master Cyl out of sight in pic was real loose and caused play - will adjust and see if I can keep my Man card...
#32
Gimme back my Man card...
Adjusted the clutch pedal per issues above AND took the truck out of H2 (must have knocked it into gear) and took her for a drive - appears to be running like it should. Now on to some body stuff - replace newly painted shields shields underneath & note I took front valence(?) off and replacement is ready for paint then shocks & front springs etc etc...feels good & thanks for helpful expertise from all above -
old87yota (06-28-2019)
Djesch3
01-10-2019 05:48 AM
nate2002
03-12-2004 07:19 PM
