I recently sold my '04 4runner 4x4 V8 and have a handful of miscellaneous parts I would like to get out of my garage. All parts are new unless marked otherwise.
The prices listed below are OBO and do not include shipping; please PM me with your zip code and parts request(s) so I can get you a shipping quote. I will let the whole lot go for $150.00 plus shipping. I am located in Central Arkansas, so if anyone is local I can meetup.
Centric E-brake Shoes - $15.00
Front and Rear Splash Guards and Clips - $10.00
WeatherTech Front Floor Mats (Used, Good Condition, Black) - $60.00
Driver's Side Sunroof Spring (Used) - $4.00
Shifter Bezel Light (Toyota P/N 90981-11014) - $1.00
(2) Sylvania 168 Bulbs (License Plate / Side Marker / Parking Light / Map Light Bulbs) - $2.00
Transfer Case 4WD Actuator Leak Repair Kit - Includes (1) Toyota Actuator O-Ring (P/N 90301-56009), (4) AVX TC15x23x7 Actuator Oil Seals, (3) Toyota 4WD Actuator Shaft Snap Rings (P/N 90520-13002) - $18.00
Trans Fill O-Ring (Toyota P/N 90301-15004) - $1.00
2UZFE - Toyota Thermostat Gasket (P/N-16346-50010) - $4.00
2UZFE - Serpentine Belt (Duralast 883K6)- $10.00
2UZFE - (8) NGK BKR6EGP Spark Plugs - $15.00
2UZFE - Toyota Valve Cover Gasket Set (P/N's 11213-50031 & 11214-50011) - $25.00
Thanks for looking!
JD
WeatherTech Floor Mats - A little wear is visible and they could use a good scrub down, but are in overall good condition. Transfer Case Actuator Seal Kit E-Brake Shoes 2UZFE Valve Cover Gaskets Serpentine Belt & Transmission Fill Plug O-Ring Splash Shields & Clips Thermostat O-Ring, Spark Plugs, Light Bulbs
