FS[GreatLakes]: WTS- 1997 4Runner SR5 V6- $5,000 - 150k - Cleveland,OH
Old Apr 26, 2016 | 10:39 AM
DavidAlexander's Avatar
For Sale $5000 (obo)
Cleveland, OH
1997 Toyota 4Runner SR5 3.4l 4x4 Auto
Desert Dune Metallic - Oak Leather interior
152,000 Miles
Owned since Feb 2004 (80,000)
Oil changed with Mobile1 5w-30 & Toyota Filter every 5k religiously
Ice Cold A/C
Moonroof
Factory installed Keyless Entry/ Alarm
All fluids in good condition
Shrockworks Front Bumper (Powder coated) End Caps not Welded yet.
PIAA 510 Fogs lights (wired to OEM switch)
PIAA 520 ATP Off-road lights (wired to OEM switch)
Blue Sea Systems Fuse Box under hood for accessories (Hot run to trunk)
BubBuilt Front skid plate (Rustoleum)
BudBuilt Belly skid plate (powder coated)
Stubbs HD-SKO Sliders (Rustoleum) (POR-15 On plates/welds to frame)
Savage Off Road Rear Bumper (POR-15 w/ Topcoat)
Hi-Lift Mount in Rear of trunk
CB Antenna Mount - NEW (Custom, attaches to rear hatch side strike plate)
2.5" Daystar Suspension Lift (Skyjacker Hydro Rear/ Rancho Front)
265/75r16 BFG AT Tires - Worn
Currently has a Cobra WX ST ii CB installed (but not wired) below the radio in dash. Never been used. Includes coax, firestick, QD, Spring, and 90 degree connector.
99-02 Headlights
LED Tail lights
LED 3rd Brake light
Black Pearl Emblems (Limited Model)
99-02 Grill
Almost New 4Runner Carpet Mats / Cargo Mat
Husky Liners Mats / Cargo Mat
Cargo Cover
K&N FIPK (includes original stock air box/intake)
Newer Wires/Plugs
TRD TB Gasket
Comes with: New Parts yet to be installed
555 Upper & Lower Ball Joints
Chassis Select Outer Tie Rod Ends
Energy Suspension Steering Rack Bushings
Bosal exhaust system (+gaskets/hangers)
Denso O2 Sensor
Toyota Rear Diff Drain Plug
Toyota Rear Diff Fill Plug
NEEDS:
Front CV Axles (Planned on adding SAW Racerunners when done)
Rear Passenger Axle Seal Leaked (Garaged Since/Not Driven)
Rear End Links
So after years of driving this daily, I walked out to head to work and saw the gear oil puddle under the rear pass tire. Since that morning it has only been driven to the gas station down the street to fuel up once, around the block every couple weeks, and backed out of the garage. Right before the axle seal leaked the CEL came on and code was run indicating heated O2 sensor needed replacing. (Since replaced battery & no CEL). The O2 sensor was corroded on so I purchased a whole new Bosal exhaust, gaskets, hangers, and Denso O2 sensor. Before I had it installed the rear axle seal leaked. I did not register it last year because it needed the O2 sensor replaced to pass state inspection and the axle seal became #1 priority.
So fast forward to today, I have yet to start rehabbing the 4Runner, my money is tied up in other things, and we no longer have the space for this project to sit and wait. Very sad to see it go as it has been a reliable workhorse for many years. Needs to have someone complete the project and get this back on the road and the trail.
Has over $3500+ of accessories and is a solid car. We have loved the 3rd Gen.
Thanks for looking. I hope she finds a very nice loving home. Still 100% drivable, all electronics work. Only one spot of body rust on pass rear wheel well. Frame in fairly good condition for age, not rusted out.
Clean title in hand. Thanks
More Pics To Come!
Old Jul 15, 2016 | 02:34 AM
BigSteveie's Avatar
Lookin 2 buy , u know sometimes u get that bug.
Quick ? , if I wanted to drive 500 miles. Would the leak stop that .
Could u drive and replace the oil as it leaks out?
New to this vehicle , but not to fixin whats broke.
Anyway let's kick this around. You can email me at iieyes@hotmail.com
Thanks 4 ur time and trouble.
Big Steveoe
