FS[MidWest]: 4l60 built trans with Downey Toyota Gear Tcase adapter/23 spline output shaft. $500
Chevy 4l60 built trans with Downey Toyota right side output gear driven Tcase adapter/23 spline output shaft. Tcase not included.
1 piece 4l60, believe its mid 90s. Selling with adapter because you have to have the output shaft in tranny to use this adapter. Have video of it in truck working before I pulled it. Taking the truck back Toyota.
Comes with torque converter and flywheel inspection cover. Neutral safety switch plug cover is broke off, pins are still good. Wasn't used in this build.
Also have the 4.3 and Howell computer/TBI/wiring kit. If you're interested in all of it we can work something out.
$500
Located in New Richmond, OH.
gzus13
Oct 16, 2018 09:31 AM
