tips for removing a bolt with a rounded head
Originally Posted by Steveh29
Holy cow that bolt was stuck! I've always had good luck with the pipe wrench routine. Reminds me of taking my wife's new Subaru in for a 'free' first oil change at the dealer. As I walked in to the service area I saw a 'technician' tighten the drain plug on an Outback's rear axle. Outback was on the lift and he was HANGING from the wrench and jerking his body to make the nut tight. I immediately turned around and did the oil change myself.
you may have to heat it up with an acetelene torch then grab it with those vise grips be sure to use and buy and use good quality tools when you work on cars, you get what you pay for,believe me, they pay for themselfs over time or you my need to drill it out to use a bolt extractor
I had a bolt a couple of days ago connecting my exhaust pipe to my exhaust manifold and it wouldn't come off for nothing... so after I had rounded every edge and tried everything I could think of, I ran over to sears and forked over the 20 dollars for the bolt off kit (found it mentioned in another YT thread). Dropped it into a 7/8" socket and the dang thing came right off. I was surprised how well the bolt off things actually worked...
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
