Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
recommend a terminal tool to remove wires from plugs
Old Dec 17, 2009 | 05:30 AM
dntsdad's Avatar
Anyone know of a brand/model that works on Toyota?
I have been Googling but nothing really seems to be Toyota specific that I can find.
Need to take apart a bunch of plugs with damaging the connectors on the interior of a 97 Runner and a 92 pickup
thanks
dntsdad's Avatar
thanks
Old Dec 30, 2009 | 12:47 AM
wyoming9's Avatar
Red face
i don`t know of any special tool
i just use a straight pick.
There is a little knack to learning how to do this but once you do it a few times it gets easy
Old Jan 2, 2010 | 10:39 PM
ubermoto's Avatar
I just did one myself. I used the picks in the photo attached to this post:
BEGIN EDIT
http://www.milwaukeetool.com/Product...ordless+System
Sorry guys, wrong link. Here's the correct link:
https://www.yotatech.com/forums/f2/3.../#post51321834
END EDIT
Wasn't too bad. In the 'terminal' side, there was a white piece fo plastic that I 'drug' out first with a pick. Then, I used the small screwdriver to pry out the blue rubber plugs on the 'wire' side. Then it was back to the terminal side with the pick; there is a plastic tab above the metal terminal that holds it in. Got it out by using a combination move - prying up the tab with the pick while using the metal terminal as a fulcrum which simultaneously pushes the terminals back. The fall out through the round holes in the wire side.
Good luck!
Old Jan 3, 2010 | 07:31 AM
neoworm0's Avatar
You used a cordless impact wrench to remove terminals. Damn those are some skills!
Old Jan 3, 2010 | 08:14 AM
ubermoto's Avatar
Oh, you have no idea what kind of skills I got. Bowstaff skills, nunchuck skills, impact wrench skills... Chicks dig skills...
Edited previous post to show this link:
Old Jan 3, 2010 | 06:29 PM
neoworm0's Avatar
LMAO. That movie was hilarious.
MO transplant
Apr 23, 2023 11:58 AM
icentropy
Sep 16, 2020 02:47 PM
steve miller
Oct 10, 2015 01:40 AM
toyota32
Jul 6, 2015 05:42 PM
colinmil
Jul 6, 2015 04:03 PM
