Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
minimum ft lbs torque for an impact wrench
Old Mar 11, 2009 | 08:46 PM
gary96360's Avatar
hey there, i was wondering what minimum ft lbs gun do you need to remove stuck bolts like lugnuts or driveshaft bolts. like 300 ft lbs
Old Mar 12, 2009 | 05:03 AM
874runnersr5's Avatar
Depends how much your gun can put out and how big your air compressor is.
Old Mar 12, 2009 | 10:02 AM
Just Learning's Avatar
3/4 inch drive 12 hp air comp will do just fine oh ya dont worry about min ft lb go for the gusto oh yaaaaa
Old Mar 12, 2009 | 10:29 AM
Toddski's Avatar
I purchased this gun from Harbor Freight. I wasn't sure how much torque i needed as you had stated.
So far it has done its job on anything i put it through. Not bad for $20.
http://www.harborfreight.com/cpi/cta...emnumber=93566
Old Mar 12, 2009 | 07:46 PM
gary96360's Avatar
250 ft llbs isnt enough for what im doing. im doing work experience in heavy duty, commercial transport mechanics and need an impact to take off bolts off like driveshafts, ect. so today i went to canadian tire and saw a 420ft lb impact with an air ratchet and a air hammer with accessories for 100 bucks. it was on clearance 150 bucks off so i bought it
Old Mar 12, 2009 | 10:14 PM
aviator's Avatar
sounds sweet gary that should get most anything loose but be careful with that much power you might break it before you free it... unless you're working around a gastank/fuel leak a torch & breaker bar can be some good friends...
Old Mar 13, 2009 | 07:18 PM
tc's Avatar
tc
Mine is like this one ... identical to the IR, but like $50 cheaper (all Craftsman air tools are made by IR)
http://www.sears.com/shc/s/p_10153_1...9984000P?mv=rr
Kamaloha
Oct 16, 2015 05:13 PM
JUICE222
Oct 13, 2015 08:50 AM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
Pocoyota
Sep 8, 2015 02:41 PM
