Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Air comprssor hoes
Old Jan 23, 2009 | 07:14 PM
mountaineertom's Avatar
Air comprssor hoes
I have a 26 gal, 1.6 hp, 160 psi, 6.3 SCFM @ 40 psi/4.9 @ 90 psi air compressor that came with a 25 ft 1/4 hose.
What would be the advantage, or disadvantage, of going to a 50 ft 3/8 hose?
I don't want to waste my money if there is no real benefit.
Thanks.
Old Jan 23, 2009 | 07:51 PM
seaofnames's Avatar
DAM HOES!!
That doesnt seem like a problem unless you are gonna be doing a lot of air tool work with an impact gun or filling up lots of tires at once. Why not get another 25ft extension of 1/4"?
Old Jan 23, 2009 | 08:03 PM
Ha, I didn't realize I spelled hose wrong.
What I have seems to work fine. It's a vinyl hose and seems kind of stiff. The 50 footer I was looking at is rubber and feels a litle more pliable. The biggest thing I'll be doing with an impact is lug nuts.
Old Jan 28, 2009 | 09:08 PM
Stick_Figure's Avatar
Larger hose diameter is needed for some larger tools. I run 1/2" air line as the main then drop down to 3/8s for most of my stuff, but the 1000ft/lb impact needs the full 1/2" airline to do its thing.
Old Feb 16, 2009 | 05:10 PM
jessekosten's Avatar
I have had issues trying to use tools like impacts or air hammers with small hoses. Larger hose = more CFM. Even small and cheap air tools like easily available CFM.
sanctfy
Sep 13, 2015 06:33 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
old87yota
Sep 9, 2015 12:39 PM
EatChipsNow
Sep 9, 2015 01:25 AM
--Oz--
Sep 6, 2015 01:06 AM
