Wiring diagram
Wiring diagram
Hi people, new here and a new 4Runner owner as well with "new owner" questions...
I just picked up a '94 and would like to upgrade the factory stereo with a Pioneer HU I've got, but I'm not willing to sacrifice/upgrade the alrm system and would like to integrate it with the new radio, which has "alarm" outputs, but I'm not sure which wires to hook together..., anyone know or have any advice where I could go or who to contact to find out?
I'm confused. I don't own a 4runner, so that maybe why. The only vehicle I've ever experienced that had a radio integrated with the keyless entry is a 96-98 honda civic. So you have an alarm? or just keyless entry?
Originally Posted by Cebby
Originally Posted by adeptid
I have a keyless entry alarm that is integrated with the radio.
This 4Runner is the SR5 model, if that is of any help.
The best way to figure it out is to pull the radio out, with nothing else being disconnected, shut the door and try to arm the alarm or unlock the doors. I have NEVER seen ANY toyota incorporate the keyless withthe radio - only 98 honda civics iirc...
OK, I've found out that I've got a "double din" unit that is composed of a "Panasonic" AM/FM-Casstte unit that dates to '92 mounted on top of a "Fujitsu" CD player which actually has 2 antenna leads (one for the power antenna and the other for "???") coming out of the back of it along with a molex that plugs into an amplifier/distribution block with wires that lead off from there.
Otherwise, it does'nt appear that the HU is in any way tied in with the alarm system and that the "theft deterrent system" extends no further than merely disabling the HU if it is removed from the vehicle which would require a trip to a local dealership to reactivate it, thereby discouraging would-be thieves from lifting it.
Anyone with any additional input on this before I undertake my planned weekend project??
The other antenna plug is for the diversity antenna on the back side window. You don't need to hook it up.
like he said, not needed for normal radio operation
OK, got everything in and changed out and it sounds goooodddddddd!
Thanks to Cebby and Bumpin', you guys were right about the alarm being independent of the radio and a thank you to you to, snap-on, I've left the secondary antenna unplugged in order to help avoid any "diversity" my dear.
montanatruck
02-26-2017 07:07 AM
88yodabasket
07-13-2015 01:32 PM
