problem with alpine HU install
ok, so i was trying to install my new alpine cda-9833 HU tonight, and i had finished wiring up the unit with the appopriate metra wiring harness. problem is, when i get everything hooked up....no sound whatsoever. ive checked and checked and i cant find an issue with my wiring, i connected everything correctly. i have a 97 limited tr4. does anyone know what the issue might be?
http://www.4runners.org/articles/headunit
make sure you follow the same procedure here.
assuming you are just making a head unit change and nothing else:
- did you unplug and remove the amp?
- did you wire everything up correctly?
- is the mute button on?
- did you unplug the speakers?
my best guess is that you may have not wired it correctly
bob
bob
i bypassed the amp but i didnt find a place on that metra harness for the mute (audio interrupt) wire to go to. i figure that must be the issue. any suggestions?
rushw
07-18-2015 01:46 PM
crashburnoveride
07-10-2015 06:39 AM
