faceplate swap only
faceplate swap only
I have a Alpine CDA-9811 headunit installed in my 4runner. It doesn't have an auxiliary jack or USB hookup. I want to buy a different Alpine faceplate with an aux. and USB jack. Is it possible to just swap the FACEPLATE with another Alpine so I don't have to jack with dash in tearing it all apart? It was already tore apart once before I bought it and it shows by the missing rivets. Does anyone have any insight on this?
there are several adapters avaialable that plug into the cd changer port in the back of that radio. it has a set of rca cables on it that you can hook a 3.5mm jack into and listen to anything that has a standard headphone jack. im pretty sure i have one of them laying around that i could sell you for cheap, this way you dont have to spend the money on a whole new head unit. the unit i have is the alpine kca-121b
http://www.crutchfield.com/S-7ZRSlCV...t-Adapter.html
