The "Official" 3rd Gen Gas Tank Relocation Thread!
#101
Today I fabbed up the the rearmost support that attached to the crossmember I had built a long time ago. I've decided to cut down the skid plate to 27 3/4" and angle up the sides, so I've still got quite a bit of stuff to do on it yet.
Chris
Chris
#103
It's finished and trail tested at Tellico. It passed with flying colors! Hopefully I'll get some pics up soon.
Seaflea might even have a better tank for us to use on the next go around that's out of a mustang.
Stay tuned for his buildup!
Chris
Chris
#107
Originally Posted by green91runner
i seen those pics.. but i was talking about his last post... wanted to see the skid plate setup... doesn't really matter.
Chris
#108
Stay tuned for some more pics tonight, hopefully. I should have some before and after pics of the new front crossmember. I've decided not to use the FROR crossmember for now, and simply use a short 6" piece of 3x2x3/16" tubing, and 2.5' of 3x1.5x3/16 tubing, which will result in the bottom of the new crossmember being 1/2" above the frame rails.
I'll also take some final pictures of the gas tank/gas tank skid too.
Chris
Chris
#109
Here they are, completely flat undercarriage at least all the way back to the lower control arm frame mounts. Those will eventually be gone too, but too many projects before that happens.
Not great pictures being that it was in my garage, but it gives you an idea, at least.
Chris
Chris
#110
looks good chris, here is the set up I have been running for a couple of months. I modified the factory sender and userd it so the factory pump, gauge and the light work. Kinda loose some space and smells like gas but it works
#112
I leave my back window cracked at least 2 inches and all my side windows down about vent shade height. I don't have carpets and my drain plugs are all pulled in the cargo area. It only smells after I fill up now. btw now people are scared to smoke in my unit.....
#115
#116
I'm sorry guys. I started to get them back up, and then got sidetracked. Can you email me at chris@utvrally.com and I'll probably just email them to you to save me some time.
Chris
Chris
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
