What is the longest panhard drop you can get for a 2nd gen?
I currently have a Downey panhard drop bracket but it is not even close to being enough drop. I have long side cruiser coils and the bar needs to drop another 3 inches to be level. I searched for "panhard drop" and only found info on the pro comp and downey. Are there any others or am I going to have to go custom?
You're probably gonna have to go custom. Just talk to some of the guys on here that have their own fab business and one of them might be willing to build you what you need.
The procomp one will give you another inch of drop. You can also get Allpro one which I'm using with OME860 springs...which is longer than yours. It also tuck the rod higher, less likely to bend. I've landed mine on a rock a while ago when I had the Downey drop.
btw, the goal is not to get it parrallel with the axle anymore, just drop/raise enough so the axle is centered.
Originally Posted by Robinhood150
4crawler now makes a panhard drop too.
Also, check out Sonoran Steel. Look what 'SC4Runner' got...
https://www.yotatech.com/forums/show...t=panhard+drop
More info...
https://www.yotatech.com/forums/showthread.php?t=70206
From the top-level search
You'll find this page: http://www.4crawler.com/4x4/ForSale/...anhardDropBrkt
06-01-2021 01:51 PM
vanion2
07-29-2015 06:17 PM
Steezy96yota
07-06-2015 10:00 AM
