$$ of tacoma e-locker?
http://www.marlincrawler.com/htm/diff/pickup_diff.htm may get lucky and find a use one cheaper +
http://www.car-part.com/
this is a junkyard search basically. Search under "carrier" or differential - might yield different results. This is how I foumd my e-locker for retrofit i my 4Runner.
john
john
Banned - User requested
what part of it broke ? I may have an extra actuator, i might be able to let go
heres something that might help ya http://ttora.norcalttora.com/wiki/in...tuator_Rebuild
thats depends on what broke, as with mine, it was a wiring issue. about $100
or it could be the actuator, a used actuator, (if you can find one) $150 and up. thats about all i know, hopfully other will chime in with more and better info.
I'd say a complete used low pinion e-locker third member could be had for around $400-$700 depending on miles and shape. Some say a new one can be had from Toyota for around $900.
I'd say a used one would be around $400-$700 depending on miles and shape
https://www.yotatech.com/forums/show...cal+mini+truck
are you talking the actuator ???? if so, i got a great deal.
You can lock or unlock it by hand if that happens.
When I was looking at lockers last year, a used third was about $350-$400, but they typically only have 4.10 or maybe 4.30's so you're looking at probably having to regear too, so about $700 ready to go in the truck.
Can you lock it by hand also? How do you do this I'm interested to know until I get mine fixed.
Just reach under there and move the rod that the actuator attaches to. The electric is only needed to change "states" - it holds on its own once there. One of the guys in COTTORA has to slide under the truck while he's airing down to lock it, then unlocks it while airing up...
Oh now I get what your saying yeah I have the same actuator and yeah it sounds like it would be better to pull it off and rebuild it and see if it works after that.
yes, heres a great write up
e-locker cost
I have an 02 Taco TRD and the locker would not engauge. I was told that if they are not used they somehow seize up. I tried beating it with a hamer but that didnt do anything but give some satisfaction on beating something with a hamer. I had the actuater replaced with a new one which fixed the problem It cost new from toyota around $900. The dealer screwed up and covered the total cost even though the warrenty had run out. I did see one on E-bay that was used for $600 though.. good luck
