Regearing requires new locker?
Just wondering...I'm planning out mods for my FJ-40. Its likely that I'll get a locker installed in the rear initially. At some later date after taking care of a few "other" things I'll be upgrading to bigger tires and will be regearing. I'm thinking that the lockers are independent of the gear ratio, but I'd like some confirmation thats the case.
Yes. The lockers and the gears are two entirely different things. It is usually best to do both at the same time to save on labor costs but they can be done separately as well.
Doesn't the difference arise on some Dana axles where you need a X.XX ratio and up or X.XX ratio and down carrier/locker for thin or thick gears?
How wide is the front axle on a 40?
Jake, you are a lucky man!
When looking around for a Powertrax Lockright, there's just one listed for the stock axles, which to me indicated it didn't matter what the gearing looked like in side for the stock housing.
No difference in Cruiser diffs as long as the year & model are right. There were different differentials used in different Cruisers but mostly overseas. AFAIK FJ40, FJ60, and FJ80 rears are all the same, front FJ80's can be different.
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
charlie_fong
09-27-2015 10:06 PM
