Pro-Comp 3" spacer EZ-LIFT?
Pro-Comp/ToyTec 3" spacer EZ-LIFT?
Any of you have experience with this kit or know much about it? Search doesnt seem to bring up much on this kit.
They do use aluminum spacers, rear AAL, and diff drop.
EDIT: The spacer is ToyTec I believe, AAL's are procomp.
Spacer lifts are very common on this board. The msot common used ones are Revtek, Cornfed, and daystar. I know more compaines make them ie toytek, Rancho, Roughcounrty. Save your self the trouble of the pre-load lifts and do the tundra lift instead.
check out Bachmen its his idea that we all picked up. OR check out the links on SSchafers website
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
JookUpVandetti
09-30-2015 08:58 AM
4runnerFireman
09-29-2015 06:24 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
