calculate my pinion angles with measurements i made??
Help me calculate my pinion angles? I have some measurements done with a carpenter’s tool and very unsure what shim degree to get.
"REAR CV DRIVE-LINE"
DL measure from flange to flange = 39”
Measurements from:
TC (transfer-case) = 6*
DL (drive-line) = 22*
Pinion = 71* -- converted ( 90*- 71* = 19* )
My calculations: 22* - 19* = 3*
“3* shim” is needed to tilt the pinion up to align with DL.
Are my calculations correct? Should i consider cruise throttle angle? If so, what is the angle at cruise throttle?
Measurements from:
foampile
12-18-2022 01:29 PM
Jcrawl94
10
10-24-2015 04:34 PM
trailgoat
08-13-2015 05:54 PM
kirkrunner
07-27-2015 07:59 PM
