calculate my pinion angles with measurements i made??
Subscribe
Feb 1, 2013 | 10:05 AM
Help me calculate my pinion angles? I have some measurements done with a carpenter’s tool and very unsure what shim degree to get.
"REAR CV DRIVE-LINE"
DL measure from flange to flange = 39”
Measurements from:
TC (transfer-case) = 6*
DL (drive-line) = 22*
Pinion = 71* -- converted ( 90*- 71* = 19* )
My calculations: 22* - 19* = 3*
“3* shim” is needed to tilt the pinion up to align with DL.
Are my calculations correct? Should i consider cruise throttle angle? If so, what is the angle at cruise throttle?
Reply 0
Feb 1, 2013 | 03:23 PM
someone please confirm?? Thank you.
Reply 0
