BJ Spacer Question?
Old 07-27-2007, 04:31 PM
  #41
Diesel_Freak's Avatar
Originally Posted by TC4RNR
...treat the angle grinder as a loaded gun, only plug it in when you are actually grinding, turn the power switch off before you plug it in. that thing is the scariest thing in my tool chest.
Radial Arm Saw trumps Angle Grinder
Ever since I was a little kid, the sound of that thing firing up makes the hair on my neck stand up...
Glad you got'm installed, too bad about the carnage. How hard was your Steering stabilizer to get off, and what are you refering to when you say "the steering elbow"?
Cheers
Dave
Old 07-27-2007, 08:22 PM
  #42
yota_dude's Avatar
Has anybody ever had problems with the ball joint spacers? I have a rear shackle lift and wanted to relax the t bars a lil bit to flex better. would this be the way to go?
Old 07-29-2007, 03:11 PM
  #43
yjzonie's Avatar
I finished mine two weeks ago. Ball joints were way hard to pull, but they finally gave way. Pressed the studs out in two minutes flat. I used a 3" air cutter to remove the material from the Upper arm, it's alot smaller than the angle grinder. First side took to long, but the second was done before I knew it. I'm glad I did it though, truck looks great, but makes 31's look small.
Old 08-01-2007, 07:50 PM
  #44
bry-an's Avatar
did you all get new shocks when you did this ... and what about longer brake lnes? I have a 4" rear lift and it looks horribly funny I need to order all the crap at once cause I live in canada.... so what all does it take ,just shocks and bj spacers??
Old 01-26-2009, 12:19 PM
  #45
SMOD's Avatar
Originally Posted by BLKNBLU
I feel the same way, wish I had taken pics... but I was solo and it would have been: stop work, wash hands, take pic, check pic, back to work... stop work etc. Here are some I just took with everything all done.
What is that big metal piece?? It looks like it's bolted on the steering?
Also where exactly was the a arm cut?
Old 01-26-2009, 01:44 PM
  #46
mt_goat's Avatar
That's a Downey idler arm brace. http://www.downeyoff-road.com/Suspen...s/1986-95.html
09-04-2015 09:27 AM
punks_is_4x4
08-21-2015 01:35 PM
4Runnin2000
07-29-2015 06:09 PM
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
Quick Reply: BJ Spacer Question?
