ball joint spacers
ball joint spacers
i have read several threads on this topic and have yet to find a general concensus. I have a 88 pickup with a 4'' superlift suspension lift, i only have 10.5-11'' of clearance under my front skid. would bj spacers be a good idea to help get more clearance, and how much would it throw off alignment?
Yes, but it will be hard on the steering components.
The better solution is to run a taller tire. I run 33x10.50 with no lift and have the same clearance as you do.
i was running lt285/75R16 before the lift and im still runnin the same size tire, its about a 32.8'' so i already have the tire height im just looking for more clearance
Ball joint spacers work well with the 4" IFS lift kits, adds a little more lift (if needed) plus added wheel travel:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ4
kawazx636
10-06-2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
JookUpVandetti
09-30-2015 08:58 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
