Coolant leak on a 06 Sequoia
Wife's 2006 Sequoia with 45k is leaking coolant. It appears to be somewhere on the driver's side front of the engine on the upper right corner of the water pump if one was facing the engine. The bottom of the water pump / the weep hole is dry and there is no play or noise from the pump.
Any ideas or has someone encountered a similar leak? I guess I'm out of warranty?
Thanks,
Tinker
Thanks,
Tinker
Assuming this is the right engine, does it help any? Maybe the seal at the water outlet.
https://www.yotatech.com/forums/f28/...cement-163431/
Thanks for the thought.
I think it is the pump. Any idea how much a dealer would charge? I can do it myself, but I time challenged.
Does any one have a link to the cooling schematics or an online service manual?
Thanks,
Tinker
Thanks,
Tinker
I have no idea on the cost at the dealer.
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
WellsR
12
07-31-2015 03:27 PM
Tigbucket
07-30-2015 07:29 PM
vanion2
07-29-2015 06:17 PM
itzmywife's
07-25-2015 04:55 PM
