wheres the torsion bar?
ok sry if this is a dumb question but i think i found it, if this isnt it can someone please point me in the right direction.
That's the sway bar. The torsion bar is the black bar that begins at the front of the truck (near the shock) and ends under the doors.
thanks for the help guys! im guna do this tommorrow and measure the difference, sorry for another guestion but what effects does this have on the ride?
The more you crank the stiffer it gets. Most people don't go over 1.5 inches of 'crank lift' cause it puts the cv's at a gnarly angle. It takes quite a few cranks to get er movin' too. Mine are cranked about an inch or so and I have not lost any ride quality, but that's because I have about 145lbs of winch and bumper up front. If you get em too tight, you can always back em off a bit until you get the ride quality vs. lift you want.
Looking at the rust on that area I would recommend a generous dose of PB Blaster, WD40 or such the day before. Spray the top of the bolt where it screws into the nut. The good news is if you break one they aren't very expensive or hard to replace.
Here are some instructions for you: http://www.off-road.com/toyota/tech/torsion/index.htm
choppe777
05-16-2016 08:00 AM
WTB[PacNorWest]: Old Man Emu Torison Bars
A2theK
10-14-2015 07:10 AM
FS[SouthEast]: Brand new 26 mm. Downey torsion bars
HiLuxer
09-09-2015 02:43 PM
