what part is this and can I fix it?
Old 05-28-2010, 09:01 PM
nexgen91's Avatar
I accidentally broke the plastic nipple (that the vacuum hose connects to) off the part circled in red, I am trying to JB weld it back on. There is a label on the part that says not to lift the supercharger by it, I had to take it off the SC to put the jb weld on it, will this be ok, or did I mess up the "factory tuning" also does anyone know what the part is called and if I can get a replacement if my fix does not work? Thanks
Old 05-29-2010, 10:52 PM
nexgen91's Avatar
bump to the top
Old 05-30-2010, 05:11 AM
xxxtreme22r's Avatar
it's called a bypass valve
This valve is vacuum actuated and bypasses the supercharger when the throttle plate is closed enough to generate a preset level of vacuum. With the bypass valve open, the losses associated with the supercharger are negligable (Eaton quotes 1/3 hp losses when cruising at 60mph with an M90 model supercharger) Because of this, if you're easy on the skinny pedal, your mileage will stay the same.
If not functioning properly it will lead to low boost and most likely (although not confirmed) a rich fuel mixture.
Old 05-30-2010, 08:26 AM
nexgen91's Avatar
awesome info, thanks. i did drill out the hole and tap and reinstall a new nipple with jb weld to hold it in place.
Old 05-30-2010, 08:34 AM
you can try contacting trdparts4u.com and see if they have a replacement. he is also on this forum I believe.
ashersullivan88yota
01-18-2022 05:37 PM
icentropy
09-16-2020 02:47 PM
Yota.Jay
07-23-2015 08:08 PM
smiley52
07-11-2015 05:16 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: what part is this and can I fix it?
