Weird sound from rear when downshifting??
I was wondering if anyone has seen or heard of anything like this?? On my friends 97' 4X4 Taco...when you are cruising about 30 mph and downshift to slow down there is a weird grinding sound coming from the rear. It sounds almost like the rear brakes grinding, however it does it even without applying the breaks. So far we have pulled the rear brakes apart and everything looks fine, shoes have plenty of meat no leaking wheel cylinders. He inspected the drive shaft and u-joints, and also changed the rear diff fluid and everything looks fine. The weird part is that it only does it when down shifting from a high speed...not when you hit the breaks. Any ideas would be appreciated. Thanks
the1998sr5
15
07-14-2020 08:35 PM
icentropy
07-14-2015 10:23 AM
jon.r
07-11-2015 03:34 PM
