Toyota Aftermarket Switch??
The lights draw more than that; but, by using the relay, all of the strain is placed on the relay and not run through the switch.
All the dash switch is doing when wired to a relay is activating the relay and using enough power to turn on the led on the switch.
That makes more sense, it almost sounded like you had your lights wired through a 3-5 amp fuse.
#26
The only time I ever wire something without my own fuse is if I know what +12 source I am tapping into, as it should be protected already by the factory fuse box.
#27
Also, this may help:
https://www.yotatech.com/forums/f2/f.../#post51562424
reference the picture in post one to see the order of which I am speaking, but these are 3 pin switches... I'm not aware of any OEM 4 pin switches?
Road Bull
10-10-2015 04:55 PM
Suprarossa
07-06-2015 05:21 AM
Vargntucson
07-04-2015 12:15 PM
0055035976, 3rd, aftermarket, alarm, fog, gen, indash, light, stock, switch, switches, theizzardking, toyota, tundra, yotatech
