Tire pressures for 285s?
Old 11-12-2003, 06:30 AM
Lurch's Avatar
"Sarcastic?"
Who, me...?
Nahhhhh ... I just get a little perturbed when lawyers make life more difficult than it needs to be.
(my apologies to any Yota lawyers out there. You're OK. It's the Beemer-driving ones who piss me off.)
-- DM
Old 11-12-2003, 06:33 AM
keisur's Avatar
Originally posted by VF84Tomcat
"Sarcastic?"
Who, me...?
-- DM
haha, I let my wife read that email describing the install of your lift and the helpful neighbor, she was laughing her but off!
Old 11-17-2003, 05:43 AM
Lurch's Avatar
OK, here's the promised report on tire pressures for the Goodyear Wrangler AT/Ss on my '99 'Runner ...
I drew a line 1/4" in from the edge of a business card and slid it under the edge of the tread of the front tires (from the side.) It went in nearly to the edge, indicating that it could use still MORE air to fully insert the card to the 1/4" mark. They already have 50 psi.
When I tried the same measurement with the rears, the card went in waaaay past the mark, indicating that the tires had too much air in them and needed to be deflated some.
I let air out until there was only 27psi and I could STILL pass the card farther in than the mark! Since the initial problem was the squirrely feel of the new tires (presumably from underinflation), I wasn't about to have them inflated LESS than Toyota's recommended 32psi.
Therefore, my faith in this form of pressure measurement is shaky. Maybe it's the type of tire. Maybe I didn't do it right, I don't know. But I went back to 50psi and will keep them there for road travel until I hear something authoritative or start seeing bad tread wear patterns.
End of saga.
Old 11-17-2003, 06:01 AM
keisur's Avatar
End of saga.
the rear is lighter than the front, that's why you got the difference. if you load up the back then you'll want the pressure higher in the rear.
Old 11-17-2003, 06:07 AM
  #25
Lurch's Avatar
I understand that, but TWICE the pressure?? I've traditionally carried a couple of pounds more pressure in the front because of the extra weight, but not THAT much.
I'm wondering just how much I'd have to deflate to make that 1/4" mark technique work. I may play with it again, but when it fell below the recommended pressure it didn't make any sense to keep on deflating.
Old 11-17-2003, 06:55 AM
  #26
keisur's Avatar
just run 0 and run on the rim. I still need to do the test on mine and inflate accordingly so I'll let you know what I find. probably will wait until thanksgiving because I'll be tearing my steering rack apart and replacing the bushing stuff on the drivers side.
calderp
Engine Swaps
08-16-2016 05:15 PM
09-04-2015 09:27 AM
calderp
07-27-2015 09:58 AM
itzmywife's
07-25-2015 04:55 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Tire pressures for 285s?
