Third power Steering pump
Old 12-10-2011, 01:20 PM
mjeffy's Avatar
Any ideas why I am having to replace my power steering pump for the third time in less than a year and half. Its on a 2003 tacoma double cab trd with 32" tires completely stock suspension .
Old 12-10-2011, 01:39 PM
skypilot's Avatar
Crummy rebuilds? Or the cooler is blocked or flow restricted (mine is just a foot long piece of steel 3/8" pipe) . Or debris from inside the steering box is eating it up. Look at the fluid, is burnt? is there debris in the resouvoir? Is the fluild clear?
Old 12-10-2011, 03:30 PM
mjeffy's Avatar
I currently do not have cooler on ther, but i think I am definantely going to put one on this go round. Fluid looks nasty. I flushed resevoir out good on last instal I bleed fluid out of rack and pinion as best I could. Thanks for reply !!
Old 12-10-2011, 03:52 PM
Fossilized
Staff
dropzone's Avatar
are you bleeding the system correctly? cavitation will destroy a pump
Old 12-10-2011, 03:55 PM
mjeffy's Avatar
Most likely not !! Can you explain?
Old 12-11-2011, 10:03 AM
skypilot's Avatar
Its a self bleeding system. You put fluid in until it stops cavitating (nasty noise) stops then fill to "hot" marking on dipstick. Turn wheel stop to stop a couple of times to be sure you got all the air out, and its GTG.
I just did one, replaced the steering box which leaked like a sieve and had a pinhole leak in the pressure hose to boot. ran out of fluid many a time, and still works fine YMMV.
Old 12-11-2011, 10:26 AM
scuba's Avatar
You're using ATF and not power steering fluid, right?
Old 12-13-2011, 07:19 PM
drkblu4runner's Avatar
like scuba says, USE ATF not power steering fluid.... i found out just in time to save my pump
Doug4320
03-24-2018 10:11 PM
TURBOrunnerNM
07-22-2015 11:01 AM
Jonny246
07-12-2015 04:51 AM
cars-guy
07-11-2015 07:51 PM
jon.r
07-11-2015 03:34 PM
Quick Reply: Third power Steering pump
