tacoma rear diff lock and abs lights????
Old 03-06-2004, 09:26 AM
jonnydclark's Avatar
Question tacoma rear diff lock and abs lights????
Hi,
I drive a 2000 tacoma TRD. My ABS light and my rear diff lock light came on this week. I checked for blown fuses and don't have any. They have gone off twice but came back on shortly thereafter. I disconnected the battery for a few minutes but this didn't change anything. If anyone else has had this problem or has a suggestion I'd like to hear it.
Jonathan
Old 03-06-2004, 09:32 AM
RobT2k's Avatar
The abs light shows when the locker is engaged. So track down what is causing your locker to engage, start right at the differential and check all the connections there. Also just make sure you're not accidentally hitting the switch on the dash somehow
Old 03-06-2004, 09:35 AM
when I push the switch on the dash the light blinks but right now it stays lit
do you think it could be caused by a crushed/broken wire?
Old 03-06-2004, 03:36 PM
RobT2k's Avatar
Do you drive any distance after pushing the button? You have to drive a little bit to get it to engage/disengage. try little S-turns, they work fast for me to get it locked/unlocked.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Vargntucson
07-04-2015 12:15 PM
merc1100sc
06-26-2015 05:24 PM
Quick Reply: tacoma rear diff lock and abs lights????
