steering wheel hub
steering wheel hub
Has anyone installed an aftermarket wheel in your rig? I snagged a wood grain nardi and I wanted to use it. If so what hub did you use? Thanks in advance.
I *think* Nardi wheels use the MOMO bolt pattern (like a lot of other Italian-based companies like OMP ...).
If so - you want the MOMO hub adapter listed for a 1989 - 1995 PreTaco.
You might want to check out momo for a hub and see if they are the same bolt hole. If not you can check out Sweet Mfg but they are a little for expensive and require you to weld on a spline to the wheel but its also a quick disconnect.
terminator
07-27-2015 07:13 PM
