Steering rack leak...photo
Old 06-18-2009, 04:11 PM
KrashDH's Avatar
So, I was just under my truck in attempt to figure out the best way to remove my starter...when I looked at the boot of my steering rack and there is fluid/grease leaking out of it...it's not power steering fluid i don't think because the level has never gone down in the truck...and both of the hard lines going into the rack are dry.could someone point me in the right direction? It doesn't seem good...
Is there a joint under that boot that is grease-able? The boot is in excellent shape its just coming from under that boot. The other side seems tight...
Old 06-18-2009, 06:34 PM
KrashDH's Avatar
Anyone? Its making me wonder... I can't afford a new rack at the moment, so any info would be welcomed...
Old 06-18-2009, 06:47 PM
BajaRunner's Avatar
http://ncttora.com/fsm/2003/Repair_M...4wdpr/comp.pdf
Looks like maybe an o-ring is shot?
Never seen one leak before... I'd either hit up DeathCougar for a used rack or check on TTORA for a used rack. Lots of guys do straight axle swaps and take their rack and pinion off. Probably get a new(used) one for $100 and install it yourself no problem. Getting that thing repaired will probably cost a lot more.
Old 06-18-2009, 07:28 PM
KrashDH's Avatar
Is this an issue where I would have to buy a completely new rack?
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
Scotttekoch
09-28-2015 10:30 PM
gentry
09-28-2015 06:16 AM
dguzzi
09-03-2015 08:48 AM
Quick Reply: Steering rack leak...photo
