SR5 fender flare questions
After 5 years of ownership, I finally pulled off two of the stock rubber/aluminum fender opening trim pieces. I've wanted to do this each year in order to clean behind them. Well, I really should have. The pieces were packed with dirt and grit and the profile of the 'flare' had worn a faint mark into the fender from normal movement over the years. As soon as I saw the amount oif moist dirt that had accumulated, I made the decision to leave these off permanently. I managed to make the wear marks almost disappear with some cleaning and polishing, but they are still visible.
The fact is, these 'flares' are not going on again. I intend to keep the truck for many more years and have no desire to see rust forming behind these pieces. So the question is: do the slim, black plastic SR5 flares mount using the existing holes and adhesive? I'm thinking of the very low profile black textured ones that I've seen on a few SR5 models. Not the Limited flares, nor the semi-Limited SR5 flares.
I've searched and found nothing. At the moment, the truck looks newer. I'm not sure what it is - maybe the aluminum strip inside the 'flare' was starting to look dated
The truck as it looked a few days ago:
Andreas
Andreas
YOU LIKE THOSE BRIDGSTONE DEULER AT'S??
AOWRS,
The black SR5 flares will fit just like the chrome trim with no need to drill holes. I bought a set from a local junk yard and out of 8 4runners I was able to come up with a set for about $100.00. Try your local junkyards and you can find a set reasonible.
09-04-2015 09:27 AM
WTB[PacNorWest]: WTB Factory chrome fender trims 4x4
skebe22RTE
07-31-2015 02:03 PM
coffey50
07-28-2015 10:55 AM
88yodabasket
07-13-2015 01:32 PM
