Speedo Cable Lub'in
Speedo Cable Lub'in
Me and my friends are spending a day in the garage working on our cars and I decided to try to get my speedo cable lubed. I searched around and really didn't find anything inparticular so I was curious if anyone could give me a quick run down on how to lube it. I can get to it but I dunno what to use to lube it and how I should go about. If someone posted this already somewhere please point me in that direction.
I haven't done this in years (might have been in high school shop).
If you don't have a problem, don't lube it. Use lube sparingly. You remove the center part of the cable. Lightly lube it with correct grease and re-install. Do it from the lower end, too much grease will get into the speedo head, then you're screwed.
Current thought (with the price of labor in a shop) is to just replace it. Bouncing speedo is usually due to some damage on the outer housing anyway, and the labor is about the same, and lubing is not always going to help.
One for my Landcruiser was only $20
Thanks
The cable is like a spring. As it binds during rotation, it winds up a little bit (so it is slower than actual speed), then when it releases it spins faster than actual speed.......hense the "bounce" in the needle.
Keep the speedo cable away from exhaust parts and don't make any tight bends or kinks in it. It will be happy!
I just sprayed some pbblast into it and it seems to be fine now. It stopped squealling and bouncing so hopefully it'll be alright. I keep a fire extinguisher and most of my dash is out right now being repainted. So if anything happens I'll just buy a new cable. I just hate having to goto the dealer.
kawazx636
10-06-2021 03:03 PM
charlie_fong
09-27-2015 10:06 PM
