Spare Tire Help Needed!!!
Old 07-11-2004, 04:14 PM
toyota884runner's Avatar
I have a 1988 4runner. when i stick the jack handle extension into the hole to lower the tire no matter which way i turn it i cant get it to move i even squirted some of that as seen on tv super lubricant in the hole and still no luck i did not have any luck using a pipe for torque either. How can i get my spare off?????????? please help thanks steven
Old 07-11-2004, 06:25 PM
leebee's Avatar
jammed mechanism
you may have a small stone jammed in the mechanism, crawl under and take a look. if you cant dislodge it, you may have to cut the chain to drop the spare. make sure you brace it somehow, be emabarassing to explain the wheel lettering/spoke pattern imprint on your forehead at work the next day!
lee
voiddweller
19
05-02-2016 09:10 PM
BigArt70
06-30-2015 09:51 PM
LSUMatt1514
60
10-10-2003 12:30 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: Spare Tire Help Needed!!!
