So I accidentally ran into a ditch and...
Old 01-27-2005, 05:08 AM
Pedrokep's Avatar
So about a week ago I was driving while it was snowing on 95 going a little fast and I lost control of my 94 4runner and ran it into a ditch. THe front tire popped from impact and I got stuck in the mud. I eventually got it pulled out but because of the impact my suspension was knocked way out of wack. I so far have had two alignments and my car still vibrates pretty bad. The people who did the alignments both times said they balanced all my tires and did the alignments but didnt mention any other damage. What should I look for or what most likely is damaged that I can fix or get fixed. I am not looking to dump alot of money into this so any advice would be great.
-Peter
Old 01-27-2005, 05:14 AM
TacomaTRD's Avatar
is the rim bent? They should have noticed when balancing but you never know. Try rotating tires to see if it follows...
Old 01-27-2005, 12:31 PM
Pedrokep's Avatar
I dont think the rim got bent. it is one of those newer beefy aluminum rims. i will give that a shot though. Could the vibrations possibly be from the steering stabilizer?
Old 01-27-2005, 12:36 PM
TacomaTRD's Avatar
not sure on the steering stabilizer, but I would look at the rim. I had to replace a factory aluminum rim on my 98 that was bent by the previous owner...
Old 01-27-2005, 03:50 PM
Yamaha+Toyota=Fun's Avatar
Hows your driveshaft look?
Old 01-27-2005, 08:13 PM
Pedrokep's Avatar
Im not exactly sure what I am looking for if I were to look at my driveshaft. Is this most likely what is causeing the problem? The vibrations are at the wheels and through the steering wheel.
Old 01-27-2005, 08:46 PM
calrockx's Avatar
maybe a bent driveshaft? here's a thread discussing it and vibration:
https://www.yotatech.com/forums/f2/any-driveshaft-experts-here-34055/
Old 01-27-2005, 09:18 PM
98_YOTA's Avatar
Did you get 1 new tire? If you did is the tire the same size, similar tread design and speed rating as the others? Steering stabalizer will not cause a vibration issue. Move the tires around to see if the vibration goes away or gets worse like what TacomaTRD suggested. As for your driveline if it's bent it will cause a vibration, check for visible dents and see if your driveline is missing a weight, you can usually tell if it had a weight by checking for tack weld spots on the driveline its self if it is missing a weight you will need to get your driveline balanced, check the U-joints for play, check the tranny mounts also.
primordialbeast117
12-19-2015 12:23 PM
scott90
10-04-2015 09:21 AM
zombie_barbarossa
10-02-2015 10:54 PM
Jdgarrison
10-01-2015 05:22 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: So I accidentally ran into a ditch and...
