Snap-On Timing Belt Tensioner available in CO?
Old 08-12-2006, 09:04 PM
bigacuralvr's Avatar
He borrowed mine...and anyone else in CO, if you need it, lemme know!!
Brett
Old 08-14-2006, 12:19 AM
jct61765's Avatar
Does autozone have one?
Old 08-14-2006, 06:39 AM
Gadget's Avatar
The tool is nice. It will save some time. With it you will not have to remove the power steering pump, A/C compressor and their brackets.
If you use this time saving tool you really should replace your water pump which you really should do anytime you replace the timing belt. It seems that the water pumps fail very soon after timing belt replacements if it is not changed with the belt. I will bet that it has to do with using this time saving tool. This is most likely from the side load that is put on the water pump pulley when you push off of it to compress the tensioner.
I would also suggest replacing the idler pulley and the tensioner pulley. It will be a big PITA to change them later...
Gadget
Old 08-14-2006, 07:35 PM
youngbuck's Avatar
Yea, I'm replacing all that stuff and more when I do my t-belt sometime within the next several months.
Eggslinger
06-08-2019 03:32 PM
thefishguy77
07-30-2015 10:59 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Snap-On Timing Belt Tensioner available in CO?
