Rear Defroster not working?
Well, my rear defroster hasn't been working for a while, the fuse is good, and the button lights up. I can hear a relay click in the dash when I hit the button. The wiper works properly, and the button for the defroster only comes on when the window is up...like it should work.
I was insipred by another thread to poke around in the gate a little bit. The only thing I found out was that the two wires going to the glass itself are NOT getting power. Ever.
Anybody have some ideas? This is a 3rd gen, so the other threads don't apply.
The wires for the defrost enter in on the drivers side at the bottom . They are simple plug in types that unplug easy. Pull the panel off and lock in the latches so you can roll the window out while the gate is down. Then peak in and hopefully see that the wires came undone. btw do you have decals all over the back window? i do and that why mine wont work right now.
I do have Yotatech & Human Rights Campaign decals on the outside. But since it's outside, it should be ok, right?
Originally Posted by gapguy
Mine enter at the top of the gate..ie 3rd gen. I stripped all of the panels off this morning. All of the connectors I saw were in tact and properly seated.
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
