Rear ABS Sensors
Old 05-13-2011, 06:17 AM
scrpydoo8's Avatar
Rear ABS Sensors
Installing a new rear axle assembly and was wondering about the rear ABS Sensors on a 4Runner. Is there any certain way they are supposed to come out, they have a bolt in them that i have taken out but i can't seem to pry them out after the bolt is removed. I don't want to damage them trying to pry them out.
Any wise words from anyone?
If I can't get them out i might just cut the wire and splice in the extra set that came with my axle.
Old 05-13-2011, 06:47 AM
Nelsonmd's Avatar
Yeah, they get really stuck in there. The sensor body is round, so you can hit the spot where the bolt goes in to spin it a little bit, just to break it loose, then you have to press it out. I used a socket and a big C clamp to press mine out. It wasn't easy, but it eventually worked.
I wouldn't cut the wires. It can be pressed out with about $15 worth of tools you probably already have.
Old 05-13-2011, 07:33 AM
scrpydoo8's Avatar
Cool, thanks!
Old 05-13-2011, 09:01 AM
Nelsonmd's Avatar
The best thing might be to use a socket just under the size of the ABS body on the inside, then use a really big one on the outside (like a 36mm or similar) that will fit around the bask side of the sensor. I didn't have a 36mm at the time I did mine, but after swapping my steering rack bushings, I do.
How far along the swap are you?
sandyota
02-04-2021 11:16 AM
88yodabasket
07-13-2015 01:32 PM
87turboPA
07-12-2015 07:49 AM
Huntingtruckcletus
07-08-2015 05:26 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Rear ABS Sensors
