Quick question (too cold now)
Guest
What type of bulb would go into the brake/parking light in the rear?
And I could not get the light off Undid the two 10mm screws and it would not come out. Is the other side held on by clips or bolts?
If I remember right, there are two hour glass shaped metal pieces on the side closest to the side of the vehicle. These pieces snap into some plastic pieces. You have to get a screwdriver on the outside and pop it out, just be carefull on the paint and the lens.
yep loosen those 2 screws and smack the light with your palm on the big black piece where the crews come out (left side hit towards the left) they are 7440 bulbs. id suggest getting some 27 watt ones for the back up bulbs and using the old back up bulbs in the burntout bulbs harness (all 3 bulbs are the same type/wattage etc etc)
www.4runners.org has a write up for changing the rear lights
http://www.4runners.org/articles/taillights/index.html
Guest
Got them. $3 each bulb. Globalization and automation of production line my ass
Sylvania 7443 = double filament brake/park bulb
Sylvania 7440 = single filament reverse bulb
(for future generations who will use the search )
defrag4
07-31-2015 10:50 AM
icentropy
07-14-2015 10:23 AM
