Is this normal for 4Runner?
Old 05-12-2003, 10:24 PM
Andrey's Avatar
Originally posted by 93_Runner06
Yeah, my owners manual says you can go 103 mph in 4HI. Just the same as 2HI. You just have to be under 50 when you shift into 4HI.
Yeap, that's exactly what I did. Not too sure why everyone started to tell me that I'll damage my 4WD that way....
Old 05-12-2003, 10:30 PM
Andrey's Avatar
Originally posted by DavidO06
oh, another question. Can you get to 110 in 4th gear (overdrive)? I have to have mine in 3rd to get that high. If its in OD, it will get to 97 and stop, and if i get above that on a downhill, it slows me down. I have heard that it has both soft and a hard limiter, but i guess it doesn't limit 3rd gear.
I had mine set to overdrive with ECU on. The I-10 around Tucson is pretty flat too, no uphills, no downhills, no turns or twists. Just straight road for 20 miles.
I saw speedometer go up to 110 mph and maybe several miles more, but it is rather difficult to tell since there are no markings after that. At this time I felt governor slowing me down and well, I didn't really push it any futher past that. After all, I just was testing my tire balancing to see it holds well to the limit
-- Andrey
Del
Del's Avatar
those are very expensive in AZ
Hehe, don't come to CA then, you'd be in jail!!
Old 05-12-2003, 11:36 PM
asudan96Runner's Avatar
Re: Is this normal for 4Runner?
Originally posted by Andrey
I finally had a chance to take a trip from Tucson to Phoenix, which is about 250 miles drive each way
Were you taking back roads? Were they dirt roads? I drive to Tucson all the time and it's no more than 120 miles.
I've driven all the way to redline in 3rd gear with 4wd on. Nothing wrong with that. Now if I click the little button above 50mph, yeah it will beep at me. I've even driven with the rear locker up to 100mph.... in a strait line.
did you know that it is a good idea to turn 4WD on the freeway every few weeks for 4-5 miles to spin the gears? Most people who own runners use 4wd once or twice a year. you have to spin them gears from time to time.
Dan
Old 05-13-2003, 04:40 AM
  #25
keisur's Avatar
my owners manual says to only shift into 4H under 20 mph and 4L only under 5 mph. I read this back in '98 when I had just driven it off the lot so at lunch I'm going to go down to my runner to reread it to make sure. I guess it may be different for these "button" shifters. mine is 5 speed and I have a regular 4WD tcase shift lever to go into 4WD, no button. so never mind what I said.
Seattle_Sign_Guy
07-12-2015 12:38 PM
razorman8669
07-12-2015 12:13 PM
smiley52
07-11-2015 05:16 AM
Poncho0206
07-10-2015 06:21 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Is this normal for 4Runner?
