Installed a New Rack, TJM, Lift Kit and multiple Lights. Pictures Included.
Old 03-30-2007, 02:51 PM
Paul H.'s Avatar
Great looking 4Runner there. you did a great job.
Old 03-30-2007, 04:39 PM
Lone4runner's Avatar
very nice!
Old 03-30-2007, 05:24 PM
wormhole's Avatar
Great write-up and install. That's what I want to do to my 4runner once I get the chance and money but I'm probable going to go with the tjm 15. I'm not a big fan of the hoops. Are you going to do anything with the rear bumper??
Would it possible for you to send me a price break-down on those items. So I can get a better idea of what everything cost. If not don't worry I'll just do some more research.
Does having the basket effect your gas mileage much? I understand that sometimes with a lift you have to adjust your drive shaft (if I said it wrong I'm a newbie) did you have to do that? When you ran the lights did you run them to a seperate fuse and does running them behind the door like that cause any leaks or wear on the wires?? Sorry, for all of the newbie questions but unless you ask you can't learn. Then again the search button helps too.
Again nice build up?
Old 03-30-2007, 05:49 PM
99SR5's Avatar
wow i think im in love... just need some tires and it'll be insane
Old 03-30-2007, 07:00 PM
  #25
spaugh's Avatar
Super clean install there. Great work.
Old 03-30-2007, 08:23 PM
  #26
paddlenbike's Avatar
You finally did it! (the lift), everything looks great and the truck itself looks immaculate.
Nice work.
Old 03-31-2007, 02:51 PM
  #27
twitchee2's Avatar
WOW Freaken sick rig. Thats almost exactly how i would love to have mine look. Simple, clean and very powerful, I think you put the money in the right places. Cant wait to see it with tires.
If you could pop me a PM with the same thing that would be greatly appreciated.
Old 03-31-2007, 07:24 PM
  #28
Rock Slide's Avatar
Originally Posted by Godzilla
Looks nice. Must be like a new vehicle now after doing all those mods so close to each other.. I assume youre using ome 890's for the rear? Im surprised youre only sitting at 37 for height,, as i have read higher yields from others (with 265/70) . regardless it looks great and will be perfect with the 265/75's
Thanks, it does feel like a new vehicle.
Correct, 890s in the rear. Actually, it's sitting higher than I expected. At SonoranSteel.com, Steve states this lift as gaining 2.0" in the front and 2.5" in the rear. I gained 3.0" in the rear, so I'm pleased.
I'm running the TJM T-15. You're probably thinking about the T-17...the one w/o the hoops.
I would like to get some type of "fabbed" rear bumper. Maybe a BruceTS when he starts rolling them out.
No problem, I'll PM you a price break-down.
The basket, lift & bumper has not affected the overall mpgs near as much as I had expected. I'm somewhat of a "conservative" driver anyway, but before all the mods, I was averaging 300 miles to a tank. That's roughly 70% highway commuting & 30% city.
After the mods, I'm still getting 280 - 300 mpgs. However, I think that is due in large part to being easier on the throttle and I'm sure the warmer weather helps too.
The basket is very aerodynamic and low profile, so that helps.
No drive shaft adjustments were needed.
Yes, both front and rear aux lights have seperate fuses.
No, running the lights behind the door like that does NOT cause any leaks or wear on the wires, Plenty of room for both the wires and drainage.
Don't be sorry for all the questions, we are here to help each other out.
No problem.
Old 03-31-2007, 07:43 PM
  #29
Rock Slide's Avatar
Nice work.
Finally, I know. Seemed liked it took forever.
Old 04-02-2007, 08:59 AM
  #30
Psalm 112's Avatar
Nice Job RockSlide! Looks Good!!
Old 04-02-2007, 06:16 PM
  #31
pius222's Avatar
Wow, that's where I want to be...
I love your ride, I just got mine last week, and would like to start modify it, would you please also send me the price breakdown?
Thanks.
Randy
Old 04-03-2007, 04:33 AM
  #32
Rock Slide's Avatar
Thanks.
Randy
Thanks and Welcome to YT!
I'll send you a PM.
Old 04-03-2007, 04:45 AM
  #33
mkgarrison5's Avatar
nice truck man! very nice
Old 04-03-2007, 06:05 AM
  #34
rocket's Avatar
I like how you installed a bunch of stuff all at once...same way i like doing things. Looks great!
I'm also wanting to know/see the same thing Mojo_Risin asked about.
Old 04-03-2007, 06:19 AM
  #35
sschaefer3's Avatar
I have asked Bill not to post that information.
Old 04-03-2007, 07:56 AM
  #36
Rock Slide's Avatar
Exactly. I simply prefer to install rather large accessories in one fell swoop, rather than piece by piece when I can afford to purchase them.
Old 04-03-2007, 08:04 AM
  #37
tommytuttle's Avatar
Looks Awesome.
I've been away from this board for a while.. got hung up on another one for a while.
It has been while since I looked into the ARB and TJM.. is there a direct bolt on now? can you give me the part number?
Thanks
Old 04-03-2007, 08:26 AM
  #38
Rock Slide's Avatar
Originally Posted by tommytuttle
Looks Awesome.
Thanks
Both the TJM T-15 (the model I have) & the TJM T-17 without the hoops are direct bolt ons.
The ARB models require a little more work to fit, but not much. Others who have ARBs installed can give you more information on what I'm describing. I'm sure they can give you part numbers as well.
icentropy
09-16-2020 02:47 PM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Installed a New Rack, TJM, Lift Kit and multiple Lights. Pictures Included.
