Independant Fog lights on 2001
Old Jan 24, 2010 | 03:09 PM
AlexJet's Avatar
I looked at the forum, but can't find right info. I know it can be done and I think I saw members referred that they've done it. On my 2005 it was an easy, like grounding one pin to another in steering column and getting power from marker bulb in headlights to fog light relay. There should be something for 3rd Gen as well.
I need fog lights on 2001 Limited be operated independently from low beam, read in parking light, low beam and high beam options.
Please help me find right information of how to do it. If you know the link and can post it up it will be very much appreciated.
Old Jan 24, 2010 | 04:03 PM
JWaldz's Avatar
I used this method >> http://www.top4runners.com/ja/fogmod.html but There is a cleaner install that takes a little longer here >> https://www.yotatech.com/forums/f127...ght-mod-87997/
either way has the same outcome.. which is ur fogs to be used while low or high beams independently.
Old Jan 24, 2010 | 04:07 PM
AlexJet's Avatar
What about when only parking lights are on?
OK, I found that it does work wth parking lights as well.
Old Jan 25, 2010 | 01:20 PM
AlexJet's Avatar
In the write-up it stays that the process will not work on 2000+ as they have DRL and gives a different option with modding DRL wiring.
My question is if I already disable DRL on my truck, would I still be able to perform original mod or DRL wiring still need to be modified?
mussy01
Dec 13, 2016 08:20 PM
AkitaDog
Sep 1, 2015 08:05 AM
93toyoguy
Aug 2, 2015 07:41 PM
highonpottery
7
Jul 18, 2015 02:48 PM
mengquis
Jul 13, 2015 10:39 AM
