IFS diffs Suck big time
Old 12-31-2003, 06:25 PM
Hyperlite's Avatar
Question IFS diffs Suck big time
My front diff is making clicking sounds after 300 miles. I drained it to find alot of metal shavings. It pulls to the left in 4wd, passenger tire barks and makes a loud "CLUNK" when disengaging. It is a new diff from Randy's Rack and Pinion. Could this be a problem with ADD or the intermedate shaft. My Drive axle and CVs are fine.
Does anyone know what this is befor I tear it apart again
If my Bronco worked I would part out my runner and send it to the scrap yard
Old 12-31-2003, 07:15 PM
Waterboy's Avatar
Sounds like the gears were set up bad or not broken in right. Did you upgrade to smaller (I think that's what you call higher numbers) gears?
Old 12-31-2003, 08:18 PM
Cebby's Avatar
Wasn't Randy's the place that Keisur had problems with? Sorry to hear about the problems. I vote bad setup IMO.
Old 12-31-2003, 09:03 PM
amusement's Avatar
There are two reponses to Randy's ring and pinon in the Yota vendor customer feed back section ...
#1 #2
Old 12-31-2003, 09:27 PM
Hyperlite's Avatar
Should have listened to Keisur............cause I am story #1
:pat:
It was 4.11 gears for the front and I had 4.10 from the factory. This front diff was built completly by Randy's. Hope it's not his fault and it is the ADD cause I don't want to rant another thread in vendor customer feed back
:cry:
lledwod
08-30-2016 01:03 PM
msane99
07-11-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: IFS diffs Suck big time
