How tight can exhaust valves be with before they burn.
Old 11-12-2005, 07:58 AM
ThomasJ's Avatar
I pulled the valve cover and measured the valve lash on the drivers side and found that the lash is as follows.
from front to back of the drivers side.
IN EXH - IN EXH - IN EXH
.009 .011 - .011 .009 - .009 .008
The last exhaust valve has me very worried. Is there any chance I have already done damage to that valve? The engine seems to run ok but I have had a noise in that area that sound like an exhaust leak. I can not find one though. The measurements were taken after the engine sat overnight at about 45 degress.
Should I be worried or am I freaking out over nothing.
Old 11-12-2005, 04:01 PM
NESW20's Avatar
what's the spec for exhaust valve lash? if it's below spec, then yes, you should adjust valve lash, which may mean re-shimming (please excuse my ignorance as to what type of valve adjustment the 3.0L has ). typically, you run more lash on the exhaust because they run hotter, as i'm sure you already know.
-Mike
Old 11-12-2005, 07:26 PM
ThomasJ's Avatar
.009 to .013 is the within spec range for the exhaust valve. .007 to .011 is for the intake. So im only 1 thousandths out of spec. But its on the low side. If it was out on the high side of the range I would not worry about it.
what really has me worried is that its cylinder number six exhaust valve that is too tight. This is the hottest valve in the motor.
Old 11-12-2005, 07:57 PM
AgRunner06's Avatar
Yeah I've read that the valve being tight will make it burn. I'd have it re-shimmed. That's pretty cheap compared to a new top end.
Old 11-12-2005, 08:01 PM
NESW20's Avatar
yeah, get it fixed before you need to pull the head.
-Mike
Old 11-12-2005, 08:46 PM
Silver_Truck's Avatar
I'd get it fixed, I burnt up #6. Or you can leave it, let it burn then put in O/S valves
Old 11-14-2005, 04:51 AM
p5150's Avatar
change the shim
Old 11-14-2005, 04:11 PM
84sr5yoty's Avatar
That's not tight enough to burn a valve. However, it is time for a valve adjustment. Good luck!
Old 11-22-2005, 06:05 AM
snap-on's Avatar
anybody have a valve shim right up?
Blamalam
03-12-2022 07:34 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
romex1
08-10-2015 06:21 PM
Snort
07-19-2015 07:03 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: How tight can exhaust valves be with before they burn.
